Originally posted by: YOyoYOhowsDAjello
I have not noticed it, but I haven't actually been awake at my apartment much while the bar is not open. It stays open until 2am or later at night. My chance to look would be when I get up before it opens, but I have not been looking for it in the morning (usually don't need to turn on my lights)
So... I don't know.
Thanks to "The Boston Dangler" on hooking me up with this!
http://pics.bbzzdd.com/users/Y...wsDAjello/IMG_0739.JPG
http://pics.bbzzdd.com/users/Y...wsDAjello/IMG_0735.JPG
http://pics.bbzzdd.com/users/Y...wsDAjello/IMG_0742.JPG
Yes, I need to dust and reorganize my cables.
I think I should have had a partner for placing that thing in the rack. Placing that 65 pound beast carefully in the middle of the shelf evenly took a bit of effort.
Cool! Yeah, I couldn't make it to Tweeter afterall, I take it that unit was from Tweeter?
Originally posted by: sdifox
so, power problem gone?![]()
Yep, Tweeter![]()
Yep, Tweeter![]()
Since I didn't have a car, and the thing weighed like 60lbs, I ducked out. I'm glad BostonDangler was able to help![]()
Yep, Tweeter![]()
Yeah, 65 pounds. I wouldn't want to walk very far carrying one.
I only have the pre-pro connected to it right now so it has hardly any load on it. The fan on mine is off right now, I know it went on when I first powered it up though. It's barely warm with the DVD player right over it, but maybe that's because it has such a low load?
When I turn the pre-pro on it does not go to battery, but that very well could happen once I hook more things up to it.
Do you plan on hooking the rest of your gear to it?
I have my amp, pre-pro, projector, blu-ray player, HDDVR, & external hard drive, and I'm just at the 25% load mark.
Originally posted by: Rubycon
Using a power conditioner/UPS - even a very high quality one - is discouraged as a corrective aid against chronic power feed anomalies. The purpose of conditioners/UPS is to guard against temporary changes in power supply specification due to neighboring devices and/or disruptions and anomalies due to weather or line workers, etc.
I'd recommend having a qualified electrician and/or person trained in mains power supply problems check everything from the premise service entrance down to the branch circuit(s) you are experiencing the issues on.
Remember AVR uses a buck/boost winding on a conditioning transformer and the further the incoming voltage deviates the harder this part works. It's not designed for full buck/boost (the latter is more important) duty continuous! Of course if it falls outside the programmed range (usually >15%) the unit will run its inverter.
I was not planning on hooking my amp or any high power items up to it.
roger that!
what is the wattage for the projector, and is there a recommended range for the power supply? max is 1200VA?
Just wanted to bump this thread and thank people for the advice again.
My lights have been flickering quite a bit tonight and my Panamax's voltage regulation light has been going on and off while I've been watching my projector tonight.
