Power Color Radeon 9600Pro Replacement?
Thanks for the reply.
$150 or less
Shuttle AN35
Barton 2500
Win XP Home
1gb RAM
Plextor 712
Lite On 165h6s
Power Color Radeon 9600 Pro
For $150 this x800pro would be about 3x as fast as a 9600pro
http://www.newegg.com/Product/Product.asp?Item=N82E16814102606
This 6800gs would also be about 3x as fast, for $140 after mail in rebate
http://www.newegg.com/Product/Product.asp?Item=N82E16814143045
For a bit less money, get this x800gto for $129 - it's about 2-3x as fast as a 9600pro
http://www.newegg.com/Product/Product.asp?Item=N82E16814102609
If you want to go even cheaper, then look at this x1600pro for $114, about 2x as fast as a 9600pro
http://www.newegg.com/Product/Product.asp?Item=N82E16814102666
