BaneSilvermoon
I wasn't sure what thread to put this in.... actually I'm not even sure I should be asking at Anandtech heh, but I thought I'd check in-case anyone around here knows. I'm sure there are some modders around who have some electrician knowledge.
I'm trying to find out what kind of heat ... I guess the "wire insulation," if that's even correct terminology, on a PSU can handle before it starts melting.
Basically, if I were to take one of these wires out of one of those 4 pin molex connectors and sit it against a piece of 150 degree (f.) metal for a couple days, would the wire insulation melt?
I figure this should be easy to find online but I'm having trouble working together all the correct terminology to find what I'm looking for heh.
::edit::
I guess I'm looking for a thermal operating range rating? Fan thermal sensors are pretty much the same type of wiring as far as the insulation right? And they can safely be placed within the fins of a heatsink that may be pulling heat off of a 200F processor.
::edit::
