- Feb 8, 2004
- 12,604
- 15
- 81
You know that two holed plug thing that powers z-5500's? Sorry google image search isnt helping and i cant describe it any better. But theres other appliances that use the same power socket (like how kettles use the same 3 hole plug that powers computers) as the z-5500, i lost the original power cable that came with it, it had a 3 amp fuse in it. But i found another one that fits, it looks the exact same, it came with a digital camera (specifically the olympus kini S 5megapixel) and was used to charge the battery. The fuse in it is also 3 amp, so will it work in my z-5500's? Is there anything im overlooking? I dont wanna plug it in unless im sure it will work.
