Power button on Antec SX830.
barlav
340
Could someone tell me what I should see when I look through the back ot the case in to the circular slot where the power button is? I can see 3 "pins" on the left that look like there angled left and a pin on the upper right and then the connector (green and white wires with a black end I believe.) going into the bottom 2 rightside pins. Would this be correct? Should I need to do anything to get the power switch working other than connecting the wire to my motherboard? Thanks! :)
AMD4ME2
664
no that should be all you need to do... check the voltage switch on the powersupply too.. make sure its set to the correct voltage for your location.. I've heard that they won't even function if the switch is set wrong. my switch looks like this:
as your looking at the front of the case: dash is bent pin, period is straight pin.
- . green wire
- . white wire
- . empty
hope that helps... im suprised at how small the PC speaker is!
I haven't got a system in my case so im not real sure if mine works but thats how mine is set up..
