Power Adapter for 2007 MacBook
MotionMan
17,124
12
I need a power adapter for a 2007 MacBook (White).
Can I just grab any available power adapter from the Apple Store (or through Craigslist) (other than the newer "MagSafe 2", obviously)?
Do I need more than 45W, or is 65W or 85W too much (damaging)?
Thanks.
MotionMan
Feb 25, 2011
16,999
1,628
45w/65w/85w refers to the capacity of the power supply - the laptop will only draw what it needs. You just want to make sure you get one that meets or exceeds what you already have. (I've pretty sure most base macbooks were just 45w units.)
I've used generic $25 adapters from FleaBay with my old macbook, they were fine. But yeah, any Magsafe should work.
MotionMan
17,124
12
Thanks.
MotionMan
Eug
24,175
1,816
Unless you're broke, don't buy the eBay ones. Their build quality often sucks.
BTW, I prefer the adapters with the right angle connector.
MotionMan
17,124
12
Yeah, I was planning on buying a used Apple adapter on Craigslist.
MotionMan
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
The white and aluminum "MacBook"s were 65W systems. Airs are 45W.
manly
13,569
4,233
I thought 45W was introduced for the MacBook Air, while regular MacBooks all use 65W?
The Apple adapters have great internals but the connectors are not exactly built to last. For a 2007-era machine with a "legacy" MagSafe connector, I'd roll with a generic. But I'm cheap like that. :D
Eug
24,175
1,816
Good point. I just looked up the pricing and it's $80 even for the lower Wattage models. Ouch. I thought they'd be $50. In that case, I'd be tempted to cheap out too for a 2007 MacBook.
BTW, I've had a couple of the T-shaped connector adapters and one L-shaped connector adapter. I get the impression the latter holds up a bit better.
