- Apr 12, 2008
- 3
- 0
- 0
Hello. I have a fairly high OC'd system that has been acting strangely lately. When restarting computer, it sometimes powers off comepletely (i.e. all fans stop, lights go out, etc.) for a split second before booting up again. SOMEtimes, when this happens, it'll actually get stuck in a loop where it will power off/power on repeatedly and indefinitely until I flip the switch on the back of the PSU to off and then back on, and hit the power button to restart the system. I have a fairly powerful video card, an OD'd CPU, two hdds and a dvd burner, so I'm wondering if it could be a lack of power. Also, I plan on adding yet another HDD, a 10,000 RPM WD RaptorX, so please advise on wether or not you think I may want to upgrade at that time even if I don't now. I think this SHOULD be enough power, but like I said, I'm doing a 1GHz OC, and about to have 3 HDDs and a DVDRW.
Here's my System:
Core2Duo e4400@3.0Ghz w/Arctic Cooling Freezer 7 Pro
2x1GB Kingston HyperX 1066 @ 1000MHz 5-5-5-15 2.1v
Gigabyte GA-EP35C-DS3R @ 1200MHz FSB
ECS 8800GTS 512 G92
Linksys Wireless-G PCI Adapter
SAMSUNG 20X DVD±R SATA
WD 150GB 10000 RPM SATA (On it's way)
WD 750GB 7200 RPM SATA
WD 80GB 7200 RPM IDE
Antec P180 Case (3 120mm fans, low-med speed)
Enermax 535W PSU
Here's my System:
ECS 8800GTS 512 G92
Enermax 535W PSU
