Potatoes and Onions for Crock Pot Roast
iamtrout
3,001
Is there any difference between the various types of potatoes and onions for pot roast?
Which kinds do you recommend?
Which is better: Crock Pot or Dutch Oven?
Which is the best cut of beef? IronWoodes said he used blade steak; I've always used, well, roasts.
Ryan
27,519
The kind you like - I prefer Red Onions, because they have a little more flavor, doens't matter on the potatos IMHO.
Tom
onions- big cooking onions are the best.
potatoes- idaho or russet are fine, sometimes i prefer a mess of the red skinned new potatoes instead. don't have to peel the red skins, just wash 'em well.
iamtrout
3,001
What exactly are "big cooking onions?" Yellow onions? White onions?
Amused
57,213
18,957
Red onions are great raw because they are mild and have a good flavor, but horrible cooked. The flavor cooks right out of them and they end up rather bland.
For a pot roast you want a much stronger onion like a white or yellow onion.
Feldenak
14,090
I agree except that red onions are delicious in a homemade calzone or pizza.
Jzero
18,834
For pot roast, I usually use either baking potatoes quartered, or little new potatoes, which you can just drop right in. I usually use yellow onions, but if I have pearl onions I like to use them as well.
I usually use a chuck roast. You don't need super high quality meat since the slow cooking process will make just about any meat super tender. A nice layer of fat is helpful for making gravy.
Between crock pot and dutch oven, I prefer the crock pot because I find things don't burn to the bottom since the heating element is situated on the side. I'm also less uncomfortable leaving a crock pot unattended as opposed to a burner.
iamtrout
3,001
Thanks for the input guys! Any cooking times on the pot roast? It's 6PM right now... if I get everything set by 7PM can I have a good roast by midnight?
When should I throw in the veggies? Just throw them in along with the meat? Any need to brown the meat on all sides?
Jzero
18,834
5 hours is a bit short, although on high it may work...I leave a roast in for 8-10 hours on low, although if you precook the roast in the microwave, you might be able to pull it off on low in 5 hours.
Normally you do not need to brown the roast unless you like it that way.
Basically here's what I do:
Put onions, potatoes, carrots and celery (if you like celery) in the bottom of the pot along with 1 cup of either water, red wine, or beef stock. Season the meat generously (I use salt, pepper and paprika) and sit it on top of the veggies with the fatty side up.
When I'm ready to eat, I pull out the meat and veggies, turn the pot to high and thicken the drippings with corn starch or flour to make the gravy.
Iron Woode
31,278
12,793
Woo Hoo!!!!
Ok I just used ordinary white potatoes and a red onion.
The blade steak was on sale. No different than a roast, just thinner.
Crock pots rule all.
1 hour on high is the same 2 to 2 1/2 on low.
So you could set it for high for 2 hours then low for the rest.
ThePresence
27,727
16
Woo Hoo!!!!
Yeah, but one hour on high is not the same slow cooked goodness as 2 1/2 on low. :)
tami
11,588
if you're going to be slicing the onions, use vidalia onions. otherwise, you will be crying.
Iron Woode
31,278
12,793
Unfortunately, I can only get them from April to July here.
