Posting problem
dutnguye
Okay so i've clock my opt146 up to 2.8 on stock volt. I ran prime test for 48 hours plus and no error. But once in a while when i boot up my comp, it won't post and if i turn the power off and boot it again everything got reset to default in order to run. Anyone has issue with this. I mean, after that i set it to 2.8 and everything runs smooth again.
If you're still on stock voltage, that's very impressive! :thumbsup: Try upping the voltage a bit to be sure your mobo isn't crapping out because of the OC...
Could well be a cold boot issue with the board... There are numerous threads out there about this mobo... Maybe it's one of the known issues... Did you experience it when the board was stock-clocked...?
nope, i' havne't really run stock clocked at all. the mobo was purchased at the same time as the chip as i know the chip potential so i clock it up from the beginning.
