Post Your Ryzen 3 2200G Idle Power Consumption
Collider
496
If you're running Ryzen 3 2200G - please share your idle power consumption.
Please mention how you measured and if using on chip integrated iGPU or a dedicated video card / dGPU.
Also, indicate if you're on 110V or 220V.
Markfw
CPU Moderator, VC&G Moderator, Elite Member
19,395
6,794
Anybody who buys a 2200g (well virtually anybody) will be using the APU in the chip, otherwise they go with something like a Ryzen 1600.
Again, 110 or 220 is irrelevant. The wattage is the same.
Markfw
19,395
6,794
OK - thanks for clarifying, good to know. I knew something was different between the two :p
Yes, amps*volts=wattage. The volts go up, the amps go down, for the same motherboard/cpu.
Chicken76
210
13
The lower the supplied input voltage, the lower the PSU efficiency will be. It's not huge, but it's a consistent, measurable difference.
The same system will consume more on 110v than on 220v. (measured at the wall socket)
ASK THE COMMUNITY
