Post your CPU Temps / HSF specs!
dkraut1
11
Curious what others are getting ...
I just built a new system using the MSI nforce board with an Athlon XP1800+ and Thermaltake Volcano7. I'm getting temps around 38C at idle and 43C to 45.5C under full load. I'm using SiSoft 2001te to obtain temps.
SWScorch
9,520
you really cant compare temps unless its to other people with the same motherboard, as different mobos adjust the temperatures differently. For example, Asus boards are known to read high, while others read lower.
But just for kicks and giggles, I get 38 idle, 41 full load on an Athlon 1.0 @ 1.3 and an Alpha PAL8045 with a 50cfm Sunon fan.
pmondoTNO
21
amd 1.4 t-bird @1.6
alpha pal8045
MSI k7t266-ru
full load 48c
case temp 34c
room temp 22c
MoFunk
4,058
If you really want more accurate temps get an LCD monitor. Like this one! I am using it. Mobo says cpu @full load is 37c but LCD shows 43c. This alone shows what a difference the mobo shows. Even LCD is not 100% right. But much closer!
J3anyus
2,774
AMD T-Bird 1.4 @ 1.4 (No OC)
EPoX EP-8K7A+
Alpha PAL8045 w/ Low Speed Sunon Fan
2 x 120mm Panaflo L1A (one for intake, one for exhaust)
Load: 40C
Idle: 36C
Anubis
78,712
427
tbqhwy.com
AMD XP 1700+ @ 1.6Ghz Core 1.87V mem 2.8 V
EpoX 8KHA+
Thermalright SK-6 w/ delta screamer
2x 120mm papst case fans. 1 intake 1 exauset. 1 80mm side intake
case 28 C
Idle 44 C
Load 48-50 C
Dan
Athlon 1.4GHz @ 1.63GHz (11x153)
MSI K7T266-A PRO2
2x256MB Crucial PC2100 DDRAM w/Thermaltake heatsinks
Alpha 6035 heatsink w/Thermaltake 6025A-2B 60mm fan
1 Sanyo-Denki 92mm Intake Fan
2 Sunon 80mm Exhaust Fans
Full Load: 48C
Idle: 40C
Case: 31C
punkrawket
1,924
Duron 800
Giga-Byte 7DXR F7 rev1.0
Vantec All Copper 6035 hs + stock delta
2 intake 80mm + 2 exhaust 80mm
Cpu - 35C idle 40C load
Case Temp - 20C
NoVo
463
Mainboard: Epox 8KHA+
Processor: Athlon XP 1600+ (10.5 * 143) 1.51 GHZ
Heatsink: Swiftech MC462A Delta 80mm (With rheostat to control RPM and volume).
Temps:
Idle: 31 c
Load: 35 c
Case: Fong KAI 320
Fans: 1 * 120mm intake, 1 * 90mm exhaust (Both Panaflows).
Uclagamer_99
2,867
ECS KS75A
Athlon XP1800+
alpha 8045 + panaflo l1a fan (80mm)
antec 1030sx case w/ 1 intake and 2 exhaust panaflo l1a fans (80mm)
idle 38C
full load 43~44C
case temp 23~25C
temps taken w/ motherboard monitor 5
scoobydooby
444
MSI pro2
1700+ not OCed
Antec SX635 w/ 3 adjustable 80 mm enermax fans
SVC Golden Gate w/ 5000 rpm YS-Tech fan
load:42-43
Scoob
pbrain
560
<< you really cant compare temps unless its to other people with the same motherboard, as different mobos adjust the temperatures differently. For example, Asus boards are known to read high, while others read lower. >>
not only that, but the thermal probes don't accurately measure the cpu temp period. i have 2 thunderbirds on kt133a mb and 1 palamino on a kt266a, i think they're really great computers for the price, but they can't read cpu temps accurately at all. worst one:
amd xp 1600+@1.4
epox 8hka+
alpha pal8045
case: 22c
idle: 35c
load: 37c
temps taken with mbm5. 2c difference from idle to load is unreal. as MoFunk said, an external probe near/touching the cpu would yield better measurements, but internal cpu thermistors would be best. if you ask me, motherboard readouts are total bs and show little, if any, relevant information on gauging cpu temps. i don't think comparing temps between systems with the same mobo are any better.
LesTheMan
7
AMD 1.2 t-bird (200 mhz FSB)
Asus a7v
ThermoEngine with 80mm ball bearing fan (very quiet)
80mm exhaust fan
Normal day in Australia:
full load 49c
case temp 37c
room temp 26c
Xmas day (middle of summer) in Australia:
full load 62c
case temp 51c
room temp 42c
Im getting an aircon next summer for me and the computer.
CorCentral
Banned
Feb 11, 2001
6,415
AMD 1.2/266 (no OC)
MSI K7t266 Pro-2
GlobalWin WBK-38
Enlight 7237 with 2 Sunon 80mm High speed fans 42.5CFM each (1 intake / 1 exaust)
EnerMax 365 PSU
Here in Florida right now , it's 19C/68F outside & about 21C/71F inside .
PCAlert3 & Bios read the same = 40C/104F (CPU) ..................... 35C/95F (Case) ------------- All at idle .
It seems my case temp is much higher than it should be but don't know if it's just the MB reading it inaccurately or what ?
I've heard that MSI MB's read higher for some reason . Anyone have any ideas ?
I did do a small mod to the case by enlarging the front intake holes to a litte over double the size that they were .
We should have a thread similar to this one but have it broken down to each MB Manufacturer & Model . Even with all the diff. mb's , cpu's & hsf's that are out there , it would be a very helpful tool & I bet it would'nt take too long to build a database with the newer setups that people have .
(or is there a site that has a similar setup already ?)
Kanalua
4,860
Celeron 1Ghz @ 1.12Ghz
ASUS P2B
Intel Retail Heatsink
CPU Temp: 54F
Two 80mm intake, 1 80mm outtake (not including PS fan)
chopstxxx
918
enlight 7237 w/:
80mm sunon 42 cfm front intake
60mm sunon 24 cfm lower front side intake
92mm ?????? ?? cfm side intake
80mm sunon 39 cfm rear exhaust
pci slot fan
60 mm exhaust on bottom of psu
3x40mm exhaust on front of psu
80mm exhaust on back of psu(stock psu fan)
3x40 hard drive cooler
2coolpc plus fan and duct system(92mm fan)
northbridge cooling fan
thermaltake mini copper orb hsf (soon to be thermalright sk-6 w/ 42 cfm sunon)
iwill kk-266
1.33 tbird@ 1.50
ambient =21
case = 23
cpu = 44
ShinSa
744
<< enlight 7237 w/:
pci slot fan
iwill kk-266
1.33 tbird@ 1.50
ambient =21
case = 23
cpu = 44
OMG!!!
You should get an award for the loudest computer!! LOL
Texun
2,058
Temps are with a room temp of 22C
34C low
36C normal use
44C high
MSI K7T 266A
XP1700
Volcano 7
80mm intake
80mm exhaust
CStroman
1,568
8KHA+
Duron 750@1050
SK-6/w 38 cfm delta
idle at 40-41, load at 44-45, depending on room temp. All temps taken with socket thermistor.
amdskip
22,530
13
Xp1800 @ 1.53 (for now)
34-37 w/sk-6 and 80mm panaflo on diagonal
soyo dragon+
Tullphan
3,507
Shuttle AK31a
T-Bird 1.4 @ 1612 (11.5*140), 1.74v
Millenium Glaciator v.1
Antec 1040B (2 antec exhaust, 2 enermax variable speed intake)
Idle: 22/35 Normal: 25/40
Oh, & did I say it was quiet? :)
Quad
1,222
asus a7v133
alpha pal6035 with ystech 27cfm fan
45 idle 49 full load
30cfm intake
50cfm backside exhaust
50cfm topside blowhole
