Give 'em to me.
Is it better to idle in Neutral? My thoughts behind this are that extended idling in Drive just unnecessarily heats up your transmission fluid.
OTOH, is it "hard" on the transmission to shift in and out of drive?
Also, in my Focus, the "2" on the gear selector causes the car to even start in 2nd gear. I've never encountered this in any of the other automatic cars I've driven.. is it common?
Anyway, I've been doing this when appropriate.. ie: don't need to accelerate quickly. I move the lever to Drive at ~15mph, after it would be out of first anyway.. so it shifts into 3rd as it would if I were in Drive the whole time. I was thinking that I could save some gas.
I don't think this should hurt the transmission at all, if anything it will save wear on 1st. Is it causing unnecessary heating/stress on the transmission fluid, though?
What is the proper way to check the transmission fluid? I've always been kinda baffled.. I swear every time I've ever checked the fluid level on an automatic, it's way over the F mark on the dipstick.
Such is the case with my car.
