Also, a better test for stability would be running enough loops of IBT so you can test for at least 12 hours, or half a day. 5 loops is pretty easy for any system. Folding@home is good for stability testing, too, even if it wasn't made with that purpose in mind.
Stability testing is for the most part is over done. I guess if you build a rig to run IBT, Prime, Folding@home 24/7 then you'd have to stress test accordingly. For most people it's extreme and subjects the rig to severe loads that will never be seen in real life.
Not that stress testing isn't important but there is such a thing as over stable at the same time for the intended uses for the rig.
4ghz at 1.152v's IBT(8-threads)(10 runs) on the high mem setting for now. The idle vcore is getting down pretty low tho. Had to use a - .115v offset to get the vcore down....Idle's at .872v's
Just using the high memory setting as it allows me to surf the web at the same time. Full load on 8 threads pretty much cripples the system when running max memory which makes it no fun to me. If I planned on running such a whimpy overclock then I'd stress test it more severely.
