POST Diagnostic/Error cards
ibex333
4,094
123
I need to get one of these cards so i can troubleshoot my hardware during a POST, but I'm not sure which one to get... There's so many of them on e-bay! Are these cards compatible with ALL hardware? Will they detect problems with newest cpu's, mobos, etc?
Can someone please link me to a card that would be good for me? Thanx very much.
ibex333
4,094
123
Originally posted by: Quiksilver
Why would you need one of those when you can just use the beep codes.
My PC doesn't do these beep codes... Do I have to buy a separate speaker for that? I don't have this feature on my mobo or on my case... :(
VinylxScratches
1,666
Are you sure your PC doesn't do beep codes? If your PC turns on and nothing happens that means it's not even reaching the initial post and is likely a serious failure on the motherboard. Check the manual or look by where you connect all the buttons from the case to the motherboard and see if there is a PC Speaker connection.
ibex333
4,094
123
Where is the PC speaker itself usually located? On the mobo or on the case?
VinylxScratches
1,666
Usually the case has a really small speaker and you connect it to the motherboard. The usual wire color is red and black and it connects where all the other connections are (Hard drive LED, Power Button, etc....).
mooseracing
1,711
Beep codes aren't presented for everything.
These cards can be alot more helpful giving detailed and direct errors, such as a corrupt BIOS chip that needs replaced.
These cards won't catch everything though either. Such as your board won't post do to a bad circuit module where your CPU's aren't even powering up.
