I'm having the same issue and found my old profile here:
http://forums.anandtech.com/member.php?u=142454
Would appreciate it if a mod could restore mine as well.
Can someone fix mine too? Mine only says 4 posts and member since 1999!
Me too please. It would take weeks for me to re-nef all that neffing.
http://forums.anandtech.com/member.php?u=171452
Thank you.
I'm having the same issue. Post count is now 2.
check everything in your userCP to be sure it's ok and fix as needed.My join date is wrong and all my old post are listed under imported_number1
My correct join date is the 26 Feb 2006
Can these 2 issues be fixed?
I sent a PM to forumsadmin on the 3 Nov 2009 and never got an answer.
I also created a thread on this issue and never even got one reply.
http://vbforums.anandtech.com/showthread.php?t=2019729
I realize you guys are busy with the change over but it would be nice to get some kind of answer.
Thanks.
??check everything in your userCP to be sure it's ok and fix as needed.
All the info I put in the user CP is OK
How do I set my correct join date and import all my messages from the imported_number1 account?
I have the same problem with lost posts and profile info and also with messages not coming over
the imported_number1 and your current account have already been merged.
OK thanks but now my post count is almost double what it's suppose to be and the join date is still wrong.
The search engine will only find about 65 posts by me and only 3 thread I started. For some reason all my post transferred from imported_number1 are not findable using number1 as the search criteria.
