post code 75
beaverbeliever41
8
I've got a Chaintech VNF4 mobo with a LiteOn DVD+RW and Samsung 160GB SATA hard drive. When powering up, I get a Post Code of 75. Any ideas on what this is?
HDTVMan
Banned
Apr 28, 2005
1,534
Are you using a pata to sata converter on the hard drive or DVD writer?
If so its a known bios problem. Not sure if they fixed it yet. Dont use the converter to Connect it.
GadgetBuilder
148
Post code 75 may be normal -- detection of IDE devices takes a short time so you see it on your screen for a bit and then the BIOS continues on. The VNF4 displays the code for each thing it does so if it stalls you know what it was doing that caused the stall/fail.
The complete list of post codes for the VNF4 is here:
http://forums.pcper.com/showthread.php?t=373815
