- Dec 5, 2000
- 43,804
- 46
- 91
i've been having trouble with my internet connection cutting out on me and opening several IE windows will usually get it going again for some reason.
well, i set it so that ZA doesn't load up at windows just to check this out. didn't have a single problem for 2 days with it off. now, i wonder if its something with ZA or the way i have it set up? i have no idea what setting it might be. i wonder if i should reinstall it and just go through the setup manually instead of using my backed up settings.
have you guys ever run into anything like this?
