Possible? with Duron 850 mhz and MSI K7Pro 266 FOR OVERClocking?
MullySculder
Banned
May 29, 2001
137
I know the overclocking thing...
This is the 1st time that I want to overclock my CPU but I do not want to blow on both Motherboard and CPU.
Should I buy another good CPU Cooling Fan?
Is it possible Overclock? My Microstar motherboard support beyand 1.6 ghz of CPU
Thanks,
Adul
44
danny.tangtam.com
You'll need to unlock your duron first. You can do this by connection the 4 pairs of dots that make up the l1 bridges.
Once you do that you can bump up the multiplier on your MB. adding voltage has need to make you system stable.
Jittles
1,341
Physically on the surface of the CPU there are a bunch of little dots, connect the ones next to L1 and then you can change your multiplier on the cpu. Connect them with a pencil. REally easy
