- Nov 17, 2000
- 3,719
- 0
- 0
I am currently running CentOS 5 32-bit. Is there a way I can install/upgrade the kernel only to 64-bit?
Thank you.
Thank you.
I think there's a huge difference between can you and should you... You probably could get it to work, but you'll probably see a ton of errors. I've been doing systems administration long enough to know that it's worth avoiding the headaches and doing clean installs where possible. It would be far easier though to tar up the directories for the apps you need, snag your configs from /etc, and reinstall Cent OS 5-64. There are some major differences in the libraries and applications that Red Hat and Cent OS supports that require a lot of care and feeding even under normal circumstances. If you tackle this, you'd better have a Cent box somewhere already running 64 bit so you can copy libraries and get all your directory rights set correct so new 64-bit applications will have what they need to function.
If that's the case then RHEL and CentOS are both severely broken. The Linux kernel run 32-bit binaries just as well as 64-bit ones, so if the 32-bit kernel works then the 32-bit one should work exactly the same. Apps that interact directly with the kernel may have issues if poorly written, but most like iptables should've been fixed a long time ago. I've been running a Debian 32-bit install with a 64-bit kernel for probably close to 2 years now without issue.
