Possible to see who's leeching off your wireless connection?
exilera
940
If your wireless connection is unsecure (or even if it is secure), is there a tool in XP that will let you see the hostnames of people leeching off your connection?
Fardringle
9,200
765
Most routers have the ability to display a DHCP clients list. Log in to the router in Internet Explorer and take a look at what is available to you. What router do you have?
exilera
940
Thanks for the reply. I have a Belkin Pre-N.
Edit: Would the hostname show up under network places?
Fardringle
9,200
765
No, it would not show up under Network Places unless they are using the same workgroup name as you are. Checking the DHCP client list on the router is the easiest way to get what you are looking for.
JackMDS
29,545
422
