- Mar 16, 2005
- 493
- 0
- 0
The options in Windows are to either have all hard drives power-down after X minutes, or to stay on permanently.
My scenario is that I have a bunch of hard drives, some of which I need often and need constantly spun-up, and others which are rarely used and which I will often never access between boot and shutdown. Is there any way to set things so that these drives will power down, but the frequently-used ones will remain running?
Any freeware that will do the same job?
I have Googled it well and found nothing. Seems like it wouldn't be that hard, theoretically.
Thanks!
Thanks!
