Originally posted by: McCarthy
The preferred method would be to use artic silver epoxy. What I do is a little less efficient, but works too. I cover the core with heatsink compound leaving the corners or sometimes the entire perimeter of the chip bare - then mix regular epoxy and put it there. Set the heatsink in place, clamp it till the epoxy sets and you're done. That's how I did my GF2, works fine. I've done a number of different things with this method, if I had artic silver epoxy on hand I'd do that, but as as long as this is working it saves me having to buy some 🙂
Unless the heat is extreme it won't hurt the epoxy, much higher than what a working heatsink installation gets to I mean.
The bigger the sink you can put on the better of course. If you have some capacitors in the way, they're easy to overcome. Just find a sink you like (Fop32 would be fine) trial fit it. Find the obstructions. For caps, easy as drilling a hole so the sink can surround it. Don't know for sure if it's bad to have the outsides of the caps connected through contact with the sink so I'd drill the holes a bit big and maybe even wrap them with some tape to electrically insulate, just because I'm not sure and it's easy. For other obstructions you might have to cut a corner off the sink, grind a patch, etc - all depends on the layout of your card.
