I have a stove top two level affair, Italian made, the type that you see in polygonal cross sections made of aluminum, but mine is circular cross sections and stainless steel. It's kind of like this but better looking:
Venus Espresso Coffee Maker, Stainless Steel, 6 cup
I have made countless thousands of cups of coffee in this, well, close to 30,000, I figure. I can make it virtually as strong as espresso, but I prefer a weaker coffee. That way I don't have to drink water. I think that
water should never pass your lips. Uh, I
always buy organic coffee. I get the stuff at Costco, grind it in my 600W Osterizer blender (which I also got at Costco).
I do grind my coffee really fine.
I have adapted my coffee maker. It came with a little round ~2.25" diameter stainless perforated barrier with a knob on top to filter out the grounds. I don't use that. Instead I cut ordinary paper coffee filters (the kind that you can press flat and are 5-6 inches in diameter) into ~2.25" diameter pieces to use in the coffee maker between the ground coffee and the chamber that receives the brewed coffee. I get 4 of these rounds out of one paper filter. One of these filters will last for a dozen or more coffee brewing sessions before I need to replace it (they either start to tear or start getting too clogged to work efficiently). I made a kind of compass device to which I have attached a razor blade to cut my custom filters. Once in a while I sit down and make a fresh batch of filters, around 100, which will last me a couple of years or so. This arrangement is very efficient in making an excellent ~14 oz. cup of coffee.
I do not believe in grinding coffee every time. I grind about 2 pounds of coffee at a time, store 1/2 in the refrigerator, leave the rest out in a plastic container. I don't believe that more frequent grinding is beneficial, particularly if you grind very fine like I do.
