Possible to convert and EXE. file to and ISO?
bjc112
11,460
yep..?
You make it sound so easy and me like and Idiot,
i tried just changing the file extension, heard that was a possiblity...
bjc112
11,460
Originally posted by: notfred
burn the EXE to a CD and rip the CD.
My man, thank you sir..
Then use ISO buster or something to that extent?
:p
ALways so helpful guys.
bjc112
11,460
FOr some reason i really was stuck in the dark on that one...
:Q
Anyways, thanks guys...
ThisIsMatt
Banned
Aug 4, 2000
11,820
:p
WTF? What are you trying to do? Your posts make no sense...
bjc112
11,460
well, Mission failed, heh
I just need the EXE, basically, i had and error at the end of the rip, so i could have a bad file...
I just want to run setup, and needed to change from exe->iso..
bjc112
11,460
:p
How so?
You can use ISo buster to rip the CD...
Am I missing sometihng?
ThisIsMatt
Banned
Aug 4, 2000
11,820
:p
How so?
Someone is missing something, that's for sure. You want to run an executable file, but you need to make it an ISO first? That makes zero sense.
bmacd
10,869
i honestly don't think bjc112 is familiar with ISOs. Fortunately, there's nothing difficult about them.
-=bmacd=-
amnesiac
15,781
bjc112 - just want to make sure you're clear on the difference.
EXE is an executable file. You run it from your computer.
ISO is an IMAGE of a disc. It is not executable.
If the exe is a setup file for a large program and is giving you errors, chances are it's corrupted and you have to redownload it.
tcsenter
18,837
496
I'm not sure I totally understand your question, but taking your question literally, no you cannot "convert" an .exe to ISO, no more than you can "convert" a dynamic linked library file to NTFS file system. The two are so different that its difficult to imagine what you're attempting to accomplish.
