Possible to connect the audio pins from the Antec Sonata front panel to Audigy 2 ZS??
NauTiKa128
590
I'm dying for a solution!
Called Antec and the rep told me that Audigy ZS is not compatible w/ the front panel connectors (headphone & mic)that comes w/ the Sonata case. He said the only way's to get Creative's I/O panel. =.=
Is it really impossible??
VictorLazlo
996
This answer doesn't apply specifically to the audigy, but if you know the pinout of the cards internal connector, then go ahead and find the pins you need and give it a shot. I find it hard to believe the audigy's internal connector is ONLY compatible with creative's I/O panel, unless they are able to keep the pinout a complete secret.
