Possible to connect ps2 to pc?
quakedog
Hey
Just wanted to know if it is possible to connect a ps2 to the pc or to just use the ps2 with a pc monitor??
Is that possible?anyone tried it??
If you had some type of video in card for your computer, such as a tv tuner, you could connect it that way. I used to use my PS1 with my tv tuner, and it worked fine.
I have a Leadtek Deluxe TV Tuner, I connect the video form the PS2 to the tuner through an adapter that is provided, and I bought a 1/8" splitter with two female ends and I plugged the Red and White RCA jacks for sound into the splitter, and the other end goes into the TV tuner. Works great, I love it.
yeah I've had my PS2 running through my hauppage WinTV Primio TV tuner and it's not too bad at all... better off using a TV though as then you can use the both at once 😉
