These wavefronts interfere either constructively or destructively depending on how the peaks and valleys of the waves are related. If a peak falls on a valley consistently (called destructive interference), then the waves cancel and no light exists at that point.
Originally posted by: Born2bwire
Also should note you cannot expect to achieve perfect deconstructive interference. You will notice that in the slit diffraction experiments that photons will still land in the regions of deconstructive interference. The inherent finite sizes of potentials and the fact that the wave equation describes something akin to a probability distribution function prevents perfect cancellation.
The banding is caused by geometry...
Originally posted by: f95toli
First of all, the photon does not have an antiparticle as such meaning you can't annhilate photons (also, where would the energy go?)
But to answer the first question: yes, sort of. Although the effects is extremely weak and can only be observed at very high energies; i.e. it can't be used for visible light or radiowaves.
It's normally distributed though, so there has to be some number of photons even in the deconstructive areas.
