slag
Wife drove my truck around town yesterday, came home, parked it in the drive, and when she went out later to leave, it just clicked. I came home, checked the battery, it was fine. You turn the key, the relay clicks, but nothing else happens. Everything inside works fine. I did swap out the battery with a known good one and got the same response.
I cleaned the terminals, but think I am going to replace the ends with a heavier duty terminal. The starter acts like its not even getting a signal -- no clicking, no nothing. The only click comes from the starter relay. It was cold yesterday and won't be in the 50s until Friday/Saturday, so, I'll take a look at it then.
If I do have to replace the starter, its a several hour ordeal, removing the exhaust manifold, dip stick assembly, etc. There is a cheater way of doing it by jacking up the side of the engine, but first thing first, I need to somehow get it in my garage and it's parked on a steep incline which is my driveway. I certainly hope its just a wiring issue, but everything, to the eye, looks good. I do know, however, that wire corrosion and rot can be hidden by the wire sheathing
