Necrolezbeast
PLEASE when you POST threads asking for input on system builds tell us...
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Gaming, Photoshop, Lightroom, MS Office, e-books, browsing.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Hoping to nail as close to $500 as possible.
3. What country YOU will be buying YOUR parts from.
USA or China, since USA is cheaper... I plan on buying from there!
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Not particularly, but for this build I do think that AMD will offer the best bang for the buck by a long shot.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Monitor, keyboard/mouse, Windows 7.
7. IF YOU plan on overclocking or run the system at default speeds.
Overclocking if possible, but due to budget I'm thinking I will have to abide by what the stock cooler and SFF case decide.
8. What resolution will you be using?
1920x1080
9. WHEN do you plan to build it?
I will be in the states at the end of August, so around then... for now I'm just going to watch for some deals and buy if it's a good deal.
So, here's what I'm thinking so far:
$80 Bitfenix Prodigy 300 mini-itx http://www.newegg.com/Product/Produc...82E16811345017
$90 ASRock A75M-ITX FM1 AMD A75 (Hudson D3) SATA 6Gb/s USB 3.0 HDMI Mini ITX http://www.newegg.com/Product/Produc...82E16813157273
$25 AR CORSAIR Builder Series CX430 V2 80 PLUS Certified (but has "extra long cables" so I'm not sure about how well it will fit) http://www.newegg.com/Product/Produc...82E16817139026
$120 AMD A8 3870k Retail http://www.newegg.com/Product/Produc...82E16819106001
$53 Kingston Hyperx DDR3 1600 2x4gb http://www.newegg.com/Product/Produc...82E16820104173
$96 Mushkin Adanced Chronos 120gb SSD (before we cry about Sandfroce, I've used upwards to 10 of them in my own builds and for friends without a single issue over 2.5 years) http://www.newegg.com/Product/Produc...82E16820226236
$110 Seagate Barracuda Green 2tb 5900 RPM http://www.newegg.com/Product/Produc...82E16822148681
Total: $574
This is just an early view of what I can get for near my price range. I would like to keep an SSD in there, and 120gb for $95 seems like a good deal (gets decent reviews and I've had nothing but good things to say about both Mushkin and Sandforce, although I may be in the VOCAL minority). The HDD would be for photos, movies, etc, so speed isn't a necessity.
As far as the case and PSU are concerned, I'm not sure if this PSU will even fit properly in the case. Or if there are better bang for the bucks out there, maybe Silverstone? The motherboard is the only m-itx board on Newegg at the moment, and seems a tad bit expensive but not by too much. CPU and RAM: Am I right in thinking that I should use DDR3 1600 when using the onboard graphics, should I go for a cheaper APU? I will want to add a video card later, but I've been gaming on my laptop w/ a 5650m for the last 2 years, so I think it will suffice for a little while. As for when I upgrade, is utilizing AMD Dual Graphics worth it these days? I remember that the scaling wasn't so great when most of the reviews for the A series were written.
Anyway, let me know what you think, what I should consider.. or how to cut costs. And, I apologize in advanced if this is unintelligible... damn Eurocup leaves me with no sleep 🙁
1920x1080
Total: $574
