Hey.
My last two weeks have been living hell, computer-wise
I went out and decided to build a new system, so far so good. I went with what I thought a standard setup these days:
Athlon 1.4 ghz
GlobalWIN WBK68 CPU cooler
Asus A7V133 + RAID
512 MB PC133 RAM
2 x IBM 7200 rpm 40 gig HDs
Server Case with a 300 Watt PSU
I decided to continue using my TNT2 Ultra until I can afford something shinier.
Now, I assembled everything, even used a spacer and Arctic Silver 2 compound, all the works. I turn on the power, the fans and HDs power up and... nothing, no POST, no video signal, not even a beep. I try this, try that, reset the BIOS by shorting the right contacts, nothing. Frustrated, I send everything (except the case) back in. They tested it, said it's fine, but sent me a new Fan and MOBO anyway. Same problem. Now, the PSU can only support a maximum of 150 Watt on the leads that count (sorry, forgot which ones
), could my problem lie there? I heard that the TNT2U is a power hog, as is the 1.4 ghz Athlon. Should I get a brandname 400 Watt PSU and hope for the best?
Thanks for any suggestions.
-filarion
Athlon 1.4 ghz
Asus A7V133 + RAID
512 MB PC133 RAM
-filarion
