I have a Gigabyte Geforce 7800GT video card running on a Asus A8N-SLI motherboard nForce4, and while my PC works great and games run smooth I am curious about something.
When I run dxdiag, save info, and then open up the text file it doesn't show what my video card is...it's all blank. Also while I am in dxdiag if I click the Display tab and look under the Device it doesn't show any video card. I'm a little confused. While I'm in the dxdiag.txt file it shows:
Display Tab 1: No problems found. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
The thing is...I have the latest Nvidia drivers WHQL Forceware 91.47.
Anyone have any insight as to why this is? Thanks very much!
Here is some of my dxdiag.txt relating to the video card:
DxDiag Notes
DirectX Files Tab: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name:
Manufacturer:
Chip type:
DAC type:
Device Key: Enum
Display Memory: n/a
Current Mode: 1024 x 768 (16 bit) (42Hz)
Monitor:
Monitor Max Res:
Driver Name: RDPDD.dll
Driver Version: 5.01.2600.2180 (English)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 8/4/2004 08:00:00, 92168 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD:
Mini VDD Date: n/a, 0 bytes
Device Identifier: {D7B70EE0-4340-11CF-346B-282AAEC2C835}
Vendor ID: 0x0000
Device ID: 0x0000
SubSys ID: 0x00000000
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
Card name:
Manufacturer:
Chip type:
DAC type:
Device Key: Enum
Display Memory: n/a
Monitor:
Monitor Max Res:
WHQL Logo'd: Yes
VDD: n/a
Mini VDD:
Vendor ID: 0x0000
Device ID: 0x0000
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel:
Registry: OK
