Possible problem with the Emotion Drop Down List Tool
osmo
1,379
It appears that you cannot use the Emotion Selection List tool to insert the same emoticon twice in a row without deselecting it somehow. IE, you must insert another different emoticon and then delete it or go to the top of the list and highlight "Select" and then return to the original emoticon you were trying to insert.
Osmo.
Jason Clark
That is javascript. Now, all you have to do is go back up to the select option then back down to the smiley you wanted. Works fine.
osmo
1,379
Zuni-
Thanks for looking at it, I discovered the go up to the select option and try again method too. (see original post)
While it works fine, it's a bit inefficient. I thought perhaps it was something that might be repaired. /me whacks the author of the object!
Osmo.
Jason Clark
It's not an object ;) its just a simple onchange event.. so there isn't alot that can be done :) Smack the guys that wrote the js language :).
Killbat
6,641
Couldn't you use a "submit" type button? That would prevent the scrollwheel "feature" :)
:eek::D:|:(:Q:);):p:cool::disgust::frown::confused::frown::disgust::cool::p;):);):p:cool::disgust::cool::p;):):Q:(:|:D:eek::eek::D:|:(:Q:(:|:(:Q:);)
