Possible Overheating Problem w/4200
cp2001
13
I have a gainward geforce4 ti 4200, the 64mb version, and when i'm playing games or even just surfing the web my computer screen turns a certain color or colors, usually green or yellow. It's hard to explain but it doesn't necessarily freeze but it gets really slow and the screen is made up of a bunch of squares usually different shades of green or yellow. I originally would have thought this was a driver problem or a conflict somewhere but the odd thing is if you press the reset button it stays that color with the squares and everything if you turn the computer off and back on it works fine. I am starting to think by heatsink/fan is not sitting right and causing the core to overheat but it wouldn't overheat while I was on the internet. Any suggestions?
I have windows XP home edition
shuttle ak31 v3.1
512mb crucial ddr
Xprotozoid
Yeah, I have same problem with my GF4 TI 4600 but it's constant and all the time.
hhhmmmmm...
Mingon
3,012
What psu ? try underclocking with rivatuner this should tell you if its heat
cp2001
13
Sometimes I overclock the card but usually its not. I'm going to try to underclock it to see if it still happens. I have a enlight 340 watt psu
Cabana
491
I have a Palit 4200 128mb and I have the same problem occasionally. Also, when booting the ASCII characters are pretty messed up - they get replaced with weird ones. I have to reboot a few times to fix it. I am not overclocking at all. I never had this problem with my previous video card.
Palit Ti4200 128mb
ABIT KT7-RAID
Windows XP Pro
cp2001
13
cabana, do you have weird colors too, what drivers are you using i'm using the 30.82. I have figured out it happens whether I'm overclocking or not. I think it must be a driver problem but i'm still not 100% sure.
Cabana
491
Yeah, 30.82 is what I'm using. I have a floor fan pointing at my computer now, it seems to be keeping it cool enough. :(
cp2001
13
lately the problem seems to be getting worse. Every time I play a game it seems to happen, sometimes 30 seconds into it. I think when new official det's are released I will format and do a clean install.
Cabana
491
I notice it mostly when just using Windows. The boxes start slowly, but soon enough they're covering the entire screen.
cp2001
13
My boxes appear all at once and sometimes I can still see the screen moving for about 10 seconds but then it just freezes but it has only happened in a game for me.
Cabana
491
All this talk about Gainward, does anyone else at all own a Palit card? It's a reference design and looks just like the Gainward basically...
ASK THE COMMUNITY
