- Feb 10, 2009
- 152
- 0
- 0
I recently upgraded from 7600GT to the 4830 512 mb. One reason I picked this card was the myriad of reviews on Newegg that stated this card could easily be oc'ed to 4850 levels. So after I dropped this in my system, I used ATI CCC and let it detect the best oc settings. It set the GPU to 690 Mhz and Memory to 1100 Mhz. So I started up Fallout 3 and was disappointed to find that shadows were all flashing green spots and there was a strobe effect, like the game was having a seizure. I continued to bump down the graphic settings until I was basically back where I started with the 7600 GT and it was running ok. So I pushed the setting back to High/Ultra High and pulled back on the oc. Finally around 600 MHz GPU and 1000 Mhz memory, I found a happy place and finished the game. Well I have been running like that while playing Left 4 Dead recently with everything maxed out and it runs well, however I still notice the occasional flash of green spots in shadows. According to CCC the GPU temp isn't going above 42c when I am playing, so why is it that I am having issues, when others seem to be able to run fine oc'ing the lights out on this card. Do I have a bad card? Need to check for updated drivers maybe?
Ideally I would like to be able to run this thing as fast as it'll go with staying around the 50c temp range, and get maximum performance in games.
