- Jun 16, 2004
- 5
- 0
- 0
Hey guys, first post. Neat.
So I just upgraded my machine to an Athlon XP 3200+, 1gb DDR400, and a Radeon 9800 Pro 128mb. I'm using an older Antec case along with the 400W PSU that came with it, Asus A7N8X Deluxe (PCB 1.xx), Sound Blaster Audigy 2 Platinum, 4 case fans, (2) 7200rpm hard drives, Pioneer A05 DVD-R/W. I did a clean install of Windows, updated all the drivers (Cat 4.6, new mobo drivers, etc.). The system runs great in 2D environments. I did burn in tests with Sandra 2004 and the CPU and memory both work fine. But when I try to run anything in 3d (3DMark03 for example), after a few seconds the monitor cuts out, loses signal and the computer hangs. I don't get any artifacting, so I'm pretty sure it's not a heat issue.
Do any of you have any ideas? One thing I've been unable to test yet is whether I have enough power. With all my peripherals, my consumption is pretty close to 400 watts, so I'm wondering if the Radeon just can't pull enough power or what? Anyway, let me know what you think.
-KGB Drummer
-KGB Drummer
