The PM was $120.00 That's 100 with tax and the 30 off.
If you had read the "Detail" part of the offer, it said the following:
The latest addition to the Zip® product line, the Zip 250 USB drive, offers an ultra-thin mobile design that meets the high-capacity storage needs for both PC and Mac users. At one inch thick and weighing just under a pound, the Zip 250 USB drive can accompany the most demanding mobile computer user. Connect the drive conveniently with the industry-standard USB port, or for mobile users, the drive also provides a host-powered PCMCIA interface. Explore the new features in the Zip 250 USB drive from Iomega in the At-A-Glance list below.
The Zip 250 USB drive At-A-Glance:
Ultra-thin, mobile design. Compatible with USB-enabled PC and Macintosh systems. Requires MacOS 8.1 or higher, or Windows 95, Windows 98. Connects via PCMCIA interface with Windows 95 or Windows 98. PCMCIA connection is host powered and does not require an external power supply. Hot plug and play, except Windows NT 4.0. Up to 900KB/sec transfer rate. Includes IomegaWare? 2.1 with the latest software advancements from Iomega including QuikSync instant backup utility. Compatible with both 100MB and 250MB Zip disks. Compatible with more than 150 million 100MB Zip disksshipped to date.
Out of the box the Zip 250 USB drive includes:
Text(1) 250MB Zip drive.
1) 250MB Zip disk.
(1) Light weight USB data cable.
(1) Iomega Zip power supply.
(1) Stand that holds the drive on its side.
(1) IomegaWare CD-ROM with all the software you need to operate your drive.
(1) Welcome packet with Quick Start guide.
(1) CD-ROM containing electronic users manual.
Each Zip 250 USB drive ships with all the Iomega software you will need to install and use your drive. The Iomega software suite is designed to help you take advantage of your drive and the information you commit to reliable Zip disks. The Iomega Software suite includes:
IomegaWare? 2.1. IomegaWare is your drive's core application that allows for quick and convenient access to your files, Iomega® drive tools, diagnostic utilities, other Iomega software, Web links, and online help.
Iomega® 1-Step Backup. 1-Step Backup easily backs up data files from your hard drive to Zip® disks.
Iomega® QuikSync. With the Iomega QuikSync software, it's not only easy to back up to Zip® or Jaz® drives, it's automatic. QuikSync watches a single directory on your hard drive, and when a change is made to files there, a copy is automatically saved to your QuikSync Zip disk.
Iomega® RecordIt.RecordIt software is the coolest way to record (and play back) voice and music on your computer! Record up to21 hours of meetings, conferences and music on a single 250MB Zip disk.
That's a great buy and the device is good for laptops, too.
