I just finished putting together my first system, and after checking everything over, went to turn it on. It started powering on, and the case fans, cpu fan, and p/s fan all came on. Then after a second or two, everything stopped. :Q I tried unplugging everything except for just the mobo, and it still didn't work. So then I tried changing the fsb jumper settings from 133 to 100, and it powerewd up for a second longer before it stopped. So I'm thinking maybe it's a protection against overheating. But would my retail XP2100+ overheat that fast?? I haven't done anything to it. I'm using the heatsink/fan that came in the box with the pre-applied compound. Any ideas?? The mobo came with a heatsink already attached to the via kt333, but i remember reading somewhere, in a review or something, that it doesn't come with any compound. Should I try that?? What's up???
_Avatar_
_Avatar_
