About 1 1/2 years ago I built the rig in my sig. For around a year life was good. Then my original DFI Ultra D's chipset fan started to die. When I got an Evercool VC-RE to replace it I decided to do the SLI mod while I was at it and apparently I borked the board - it never posted again after that despite long CMOS clears, excet. excet.. A DFI rep stated that I shouldn't RMA the board as I voided the warranty just by putting the Evercool on the board (instead of sending it to them when the original chipset fan started to die.)
So, being tired of chipset fans, I got an Asus A8N-SLI Premium. It worked well at first (other than discovering that it was a terrible overclocker.) Then the primary PCI-E slot died. Fixed that by using PCI-E slot 2. Guess the SLI feature came in handy after all
. Then it developed cold boot issues, I would have to hit reset after I booted it in the morning to get it thru the post and into XP. Then it quit altogether. I RMA'd it to Newegg which was an experience in itself. The RMA process itself went well, but when I got the replacement it was an OEM white box special. I had sent all the original retail goodies back with the bad board. When I complained Newegg quickly sent me a retail box sans mobo with the goodies in it. While it wasn't the same board, I'm still not entirely sure it was a brand new mobo.
In the meantime I bought a new Ultra D to get my system back up and to try some mild OC'ing (which I had never gotten around to with my first Ultra D.) Upon installing it life was good again for months. Then I began getting one or two instances of my computer completely shutting down for no apparent reason while I was doing nothing more stressful than web browsing. This happened several more times at shorter intervals and at least once I noted an alarmingly high CPU temp (when I happened to maximize the mobo monitoring program DFI supplies.) It never popped up/alarmed until I maximized it that time(s) and I put it off as a glitch as it showed good temps after I rebooted. The Panaflo I'm using on my XP-90 seems to be okay as well. Then it developed cold boot problems and after that halted during posting and refused to boot at all, with a couple of non consistent windows error messages, then it quit even posting. The DFI diagnostic LEDs seem to show all 4 lit and then it drops down to two lit, which I believe means that the vid card and ram are okay but it's halting at the processor.
I've got a new 3200+ venice on the way, as the best I can figure is that maybe the XP-90's fan stopped long enough on several occasions for heat damage to occur with the CPU, but I just don't know. I tried installing the replacement A8N-SLI Premium mobo that I had on hand after the RMA (and had never used yet.) I can get it to post with my old CPU but it always errors out/freezes/crashes at some point during posting before trying to load the OS.
I could really use some help to try to troubleshoot this situation (sorry bout the length.)
I'm concerned about how things will go when the new CPU arrives.
