QueBert
O)k, I hooked up my car stereo today, I worked slow and was very careful to do everything right. I'm running 4 gauge from my battery to my trunk with a fuse holder next to the battery. Have a distributor block in the trunk with the 4 gauge running to it and 2 8 gauge wires coming out (1 for each amp) I bolted 2 8 gauge ground wires directly to my frame, I picked spots with no paint. Used big sized screws with crimped 8 gauge spades. I don't have a power antenna, so I used a bulb tester to find the remote wire. It was blue and lit the bulb up, so I ran that one to my trunk. I only had one amp hooked up during most of the day, I did have the radio on for a bit, not very long. I actually had the fuse unhooked a lot of the day while I ran the wire. So there would have been no drain unless it came from the remote wire not being connected properly. Not sure how long I had my car in ACC. But when I got in it tonight it tried to start and died. I got a jump and drove around a bit and it seems to be okay. The amps are supposedly 800 and 600 watts. But both are drastically overrated. They're Performance Tekniques, which are pretty much entry level amps so they BS the wattage a ton. Here's my question.
I know there's a way to test for drain on the battery when the cars off, but I don't know how to do it. I have a basic voltage meter, what do I do to test my battery? I'm not sure if it was dead because I had the car in ACC mode a lot and never started it today or what. I sort of lost track of time while I was trying to run all the wire. So it might have been in ACC mode for 3 hours or so. Not sure if that's even enough to lead to a dead battery. I'd like to test my battery for drain. To be safe I unhooked what I thought was the remote wire from my head unit until I can test it tomorrow and make sure. On the head unit the no other blue wire will have power except correct? I suppose if I wake up and it won't start I know there's a problem, but even if it starts I want to make sure there's nothing causing a drain on my electrical system.
It's a 2000 Taurus if that makes any difference. Head Unit is not stock either.
