Possessed wireless network
TechnoPro
This was a bizarre case I saw today. Linksys 802.11b router maybe 30' away (in line of sight) from laptop with Linksys card.
The client complained of slow internet. The other laptop in the house (down 2 flights of stairs) showed none of the slowness. The problem laptop would exhibit slowness when opening a web page, as in the page would half load, pause for a long while, then resume. When I did a standard ping of the router, most times, one of the 4 requests would time out. Signal strength was reported as excellent...
I could not log into the router to check settings using defaults or customer-suggested username/password. So I did a hard reset, then upgraded the firmware. I renamed the SSID, disabled its broadcast, and enabled WEP. Downstairs laptop was cruising.
This is where it gets odd. I first set up a new wireless profile in XP SP2 and it worked, but erratically. As in sometimes it would connect, other times it would not. Frustrated, I turned to the Linksys WLAN utility and that seemed to get a better connection instantly. Speeds were much improved over the original state - no more stunted opening web pages.
With signal strength at 86 - 100%, the Windows would report the connection as lost and the Linksys utility would grab onto some other ?MSHOME? network (56% strength) from a neighbor I presume.
So I?m struggling with 2 issues:
* Why is the Windows Wireless client flaky? Can it be made to work?
* What are some ways to prevent this PC from latching on to the neighbors?
Thanks.
As for the Windows Client, I'm not sure since I don't use it. I always prefer to use the card provided client since theoretically it should be more compatible since it's made specifically to work with that card.
As for the neighbors computer... most wireless clients will connect to whichever network they find that is the strongest. Unless the wireless clients supports connecting to things in a specific order. You could create a profile for his own wireless and create one for the neighbors wireless and put the neighbors one as a lower priorty (if it supports that). Or of course you could tell the nighbor to stop broadcasting his SSID.
I fixed it. I updated the WLAN card drivers and the Linksys utility, and did some more under the hood tuning and now it all works.
