I want to design a ported box to house 2x 12" Inifinity REFERENCE 1230w subs. I've been doing tons of research and found most of what I need, but there are still a few questions.
Most of the information I have pertains to only 1 sub. I'm going to be using 2 subs so I don't know what I should do with the values the manufacturer gives me (especially the vbox). For one sub, the vbox is 2 cubic feet. So for 2 subs, would I double the vbox to 4 cubic feet?
That would be logical, but I'm thinking there is a fudge factor involved. Please help me all you experience box builders!
Just finished a design and it is below. The main question that I have is port placement!? Does it matter where the port goes as long as it is built to specification? Also, because I have 2 subs, do I just double the volume from 2ft^3 to 4ft^3? I also want to know some general guidelines of how far to put the subs away from the edges and how far apart from each other.
I plan on using PVC Pipe for the port length also. Thanks guys!
DESIGN (FRONT VIEW FOR NOW): http://www.prochobo.com/Pictures/portedbox.jpg
EDIT: I'm done now. Scroll to bottom for pics
