Portable MP3 player that can read a flash drive
Tarvaln
311
Just picked up 2 2Gb flash drives for $13 a pop (thank you Wal-Mart). I'm looking for a portable MP3 player that I could plug a flash drive into and have it play songs off of that. Is there even such a beast?
Thanks
fuzzybabybunny
Moderator<br>Digital & Video Cameras
Moderator
Jan 2, 2006
10,455
35
Originally posted by: Aflac
flash drives = memory cards?
I'm thinking Memory Sticks / Thumb Drives / Keychain Drives.
There are not many MP3 players with USB ports. The only ones that I know of are the ones with 30GB+ hard drives, because those USB ports are usually used for card readers and backing up data from the card in the card reader onto the player's HDD.
fuzzybabybunny
Moderator
Jan 2, 2006
10,455
35
Originally posted by: mwmorph
Most that can do usb host should work. The X5, Gmini 402(not sure aboutthe other gminis), Zen Vision M can do it. Theres actualyl a pretty decently long list but I cant think of them all off of the top of my head.
edit how bout this?
http://www.walmart.com/catalog/product.gsp?product_id=3579125
cheap and does exactly what you need.
Ehhh... it may be hard to navigate 2GB's worth of songs without a screen. As for the other players, yeah, they should work, but the problem is that they're already 20GB+. I think the OP is looking for a cheapo player whose capacity can be increased cheaply by just sticking a thumb drive in it.
FoBoT
63,084
15
fobot.com
i have one that uses thumb drives, but it plugs straight into the cigarette lighter, so it is only portable in the sense that it goes in your car
Tarvaln
311
I checked out the VR3 and the only bad part would be I'd have to park my car in my office building. Though I think it's a splendid idea. I'm sure there are laws against that. :) I'm trying not to spend over $50 on this if possible $70 max. Thanks for these tips and if you have any others please post them.
Ika
14,264
I seem to recall reading about an MP3 player that converts a USB thumbdrive to storage space for the MP3 player... but it was a few years ago and I haven't seen it since.
Insane3D
19,446
The Sansa's have a microSD slot...not exactly what you are looking for but...
*shrug*
Ika
14,264
Originally posted by: ForumMaster
maybe something like this? maybe with a usb extender cable it'll sit?
That wouldn't work. You'll notice that the controls and headphone jack are on the USB part of the device.
Apr 17, 2005
13,465
Venzero One
its more than you want to pay, but it looks like an awesome device and i'm pretty sure it does what you need
confirmed...it takes almost any kind of usb device
mwmorph
8,877
Originally posted by: Inspector Jihad
Venzero One
That thing looks really cool, too bad tis only a 2" screen and 12gigs.
Tarvaln
311
Venzero One
Yea, this does look neat, a little more than I want to pay atm but something I'll keep in mind. Thanks :)
