Portable externals for travelling?
tinpanalley
1,511
25
Hi there, I don't buy these often and need one for work. Can someone tell me what are considered the best quality portable externals these days? I need 500GB. Are Western Digital and Samsung drives good like with 3.5 internals??
corkyg
Elite Member | Peripherals
27,370
240
To connect to what? How big? A 32GB thumb drive can hold a lot of work data and be on your key ring.
tinpanalley
1,511
25
What I'm asking about is those smaller 2.5, portable, made for travelling enclosed hdds. 32GB isn't enough for me. "a lot of work data" is subjective which is why I said that I needed 500GB. I already know I can use enclosures on 3.5s. My comments, which was improperly phrased should have been: As with 3.5s where WD and Samsung are considered the best, are they also considered the best in 2.5 hdds?
corkyg
27,370
240
My fave 2.5-in drive is the WD Scorpio Black. I would put it in a good Vantec case and toss it in my laptop bag. But - I don't need to do that. With my Thinkpad, I just replace the optical drive with the Ultrabay adapter and slap the Scorpio in there. Makes for an internal travel disk that way. :)
corkyg
27,370
240
Whoa!! Where do I get one of those? That's what I have, a Lenovo Thinkpad!
OK - what model? Ultrabay adapters are somewhat series specific. I have one for my T60 and another for my T510 - they are different and not interchangeable, although both are SATA. To illustrate:
zuffy
684
That's what I did with my XPS laptop. SSD for OS and the original 500GB for storage. Best of both world. If I really need optical, then I carry my Plextor portable DVD drive.
corkyg
27,370
240
OK, for the T420 you need trhe Series 3(III) adapter. This is in the Lenovo store - but you can get it for less. Just remember the part number and series 3 or III.
http://shop.lenovo.com/SEUILibrary/c...D77F5867D31462
Just google the part number (43N3412) and make sure it is it. It will take any 2.5-in SATA HDD up to 12mm thick. 9.5mm is ideal. That could be a WDC Scorpio 500GB. Much better than any USB external. You get internal SATA speeds.
tinpanalley
1,511
25
I love the suggestions. And I love this Western Digital. It occurs to me though that I might want to just get a 2.5 drive and an enclosure that's tough for portability because I already have an all-in-one that I can't use and the fact that it's sealed stops me from being able to just buy a new drive. So I thought if I buy a tough enclosure and 2.5 hdd as separate pieces, I can always replace as necessary. Or even keep 2 hdds. One for work, one not. Any suggestions then on this idea? I'd still get a wd hdd but any ideas on an enclosure?
stargazr
4,173
3,707
This one's nice because it has vents. Also has the carbon fiber look. USB 3.0
http://detonator.dynamitedata.com/c...com/Product/Product.aspx?Item=N82E16817256077
tinpanalley
1,511
25
Is there any difference really between a WD passport for example and a 2.5" drive inside a 2.5 enclosure? Is the passport any safer really shock-wise?
