Portable battery pack advice.
WelshBloke
32,922
11,053
Just blown up my old one and need to get a new one for summer camping trips.
Needs to have decent capacity, the higher the better.
1A USB output at a minimum.
Charge with a microUSB lead.
Be fairly sturdy.
sygyzy
14,001
4
Look on Amazon for the really highly rated ones. The ones with 400 reviews. I forgot the name brand. It's an Asian company but performs really well and is much cheaper than name brand ones anyway (which are rebadged from Asian companies).
WelshBloke
32,922
11,053
I can find things like this on Amazon but I think it uses mini usb to charge with.
I really dont want to have to keep an extra cable just to charge it with. If it uses a microUSB I can use the same cable for the wall charger, the car charger and to charge the phone up with.
wirednuts
7,121
4
i admit that i dont like the rigid protruding male connector on these, but all things considered these are excellent external power packs- http://www.monoprice.com/products/p...=10833&cs_id=1083311&p_id=7664&seq=1&format=2
the price cant be beat... for less then $20 shipped you get a rock solid power source. i keep mine in my lunchbox and anytime my phone needs a charge this will do it. only takes about an hour to charge my phone 100% from dead too, it works REALLY well. also, doesnt self drain. so charge it up and keep it laying around for weeks or months and itll still throw out a charge or two on your phone.
podspi
1,982
102
Just wondering, OP, how did you blow up your first one?
I use Moto's slim external battery, works well but is only good for ~ 1 charge. Can't say I'd recommend it for camping.
WelshBloke
32,922
11,053
Used the crappy usb lead with changeable plugs that came with it. and it's shorted something. As it's a sealed unit I can't get into it to fix it with out trashing it.
That's one of the reasons I want to be able to use the same lead to charge the phone and charger.
cytoSiN
2,262
7
Sorry for the thread necro...
Wondering if anyone has experience with the Astro or Astro2 and the Galaxy S3, and could recommend either for that phone? If not, what do you guys recommend for an external battery pack for the GS3?
Thanks!
OBLAMA2009
6,574
what is the greatest number of charges you guys can get out of one of these. are there any that will give you like 5 charges?
cytoSiN
2,262
7
This one says it does 4 and has good reviews, but I'd read them confirm accuracy of 4 charges.
I was looking for something a little smaller though, hence the questions about the Astros.
