- Jan 16, 2001
- 31,528
- 3
- 76
My head is seriously hurting. Been doing some reading. Looking at an HP 1810 switch. The configuration manual for it defines "LACP" as "Trunking" and says this:
According to that first paragraph, "Trunking" allows load balancing, which should increase bandwidth, no? The USR switch I have supports trunking but not 802.3ad...so do I need 802.3ad for what I am trying to do?
Here's a link to the manual. Page 6-1 is what I'm looking at.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c02879282/c02879282.pdf
Man, my head hurts!
Trunks allow for the aggregation of multiple full-duplex Ethernet links into a single logical link. Network
devices treat the aggregation as if it were a single link, which increases fault tolerance and provides
load sharing capability. You assign the trunk VLAN membership after a trunk is created.
A trunk interface can be either static or dynamic, but not both.
Dynamic trunks use the Link Aggregation Control Protocol (LACP, IEEE standard 802.3ad).
An LACP-enabled port automatically detects the presence of other aggregation-capable
network devices in the system and exchanges Link Aggregation Control Protocol Data Units
(LACPDUs) with links in the trunk. The PDUs contain information about each link and enable
the trunk to maintain them.
Static trunks are assigned to a bundle by the administrator. Members do not exchange
LACPDUs. A static trunk does not require a partner system to be able to aggregate its memberAll members of a trunk must be either static or dynamic.
ports.
Man, my head hurts!
