I've got an onboard LAN card and a wireless adapter.
I had previously just been using the wireless adapter, and config'd my router to forward a bunch of ports to my computer (static IP on the adapter)
Port forwarding had been working fine.
I recently plugged my Xbox into a hub, and the built-in-NIC to the hub as well, and set up ICS (XP Pro) for the Xbox to be able to get online through the router as well.
However, after I did that my port forwarding stopped entirely.
I've tried reverting settings - disable ICS, make sure the XP firewall is off, verify that i'm using a static IP, reinstall the adapter's drivers, etc. to no avail.
I've found that programs that test ports for forwarding will tell me that ports NOT being forwarded come up as "ok" but ports being forwarded come up as "NAT error"
Suggestions?!
Suggestions?!
