Port forwarding on XP Pro SP3 ...
NoobyDoo
I created a nLited XP Pro SP3 with updates till June. I left out some stuff from XP that I thought I did not need.
I have a ADSL connection. Just cannot get port forwarding OK with utorrent. But utorrent works fine. Never happened before - I've installed utorrent on many systems without problems.
Does Windows need something that I left out - some service/setting ?
Tried with three different ADSL modem/routers.
Make sure you forward on Windows Firewall (or, though I don't recommend it unless you have a firewall in your router, disable it altogether). Outside of that, Windows has absolutely no control over which ports are Stealthed, Open, or Closed.
-Kevin
