port forwarding help
song414
230
I tried to forward ports for BT today and i port trigger the same ports i forwarded. Now for about an hour and a half it worked great. Now everytime i go into my computer everything works fine for about 60 seconds after starting up and after that my email (outlook express) doesnt work and AIM doesnt connect. BT wont connect it either has "waiting" or connecting to peers greyed out (i use ABC).
Now the only way to fix this is to not port forward anything and the only temp fix i found was to reset the modem and router while my computer is restarting and it repeats it all over again. It works fine for 60 sec then does the same thing. I have a netgear rp614 v3 router and need help on correcting this issue while port forwarding. Thanks
FuZoRBlade
42
Maybe if you specify a port to forward, then it blocks a lot of other ports, so i'd just look up the ports for AIM and OE.
song414
230
i tried serveral different 1's very far apart... i still cant figure the problem out...
