I think the problem is you're using port range forwarding for single ports, that could be throwing the router for a loop. Try taking out the forwards that use just a single port from the ranges and have them on the single port forwarding setup instead. Oh and for the port 80 forward just have port 80 forward to 8080 instead.
what's wireshark and a manual port test tell you?
If the game is crashing, it sounds like your PC has problems, and that would have nothing to do with opening ports or not.I can play the game but it will crash about every other map. Been doing it for two weeks now.
I have reset the modem, router, and PC after changes so many times I have lost count.
We have tried an ARRIS router modem, a Ubee router modem (both in bridge mode) and are now using a motorola modem. All with the same problem
While I was looking around the internet for a fix I found this post. He was having the same problem I am and he is on the same cable provider in NC. I am not sure what this fix is though. I can't find the same problem in my adapter and I don't know what fix he is pointing too as the link doesn't point to a specific resolution.
I got it figured out, I feel somewhat stupid now.
I looked at the list of items in my Network Adapter's properties, where you go to set a static IP, and I saw Sunbelt Firewall Miniport. Don't ever remember installing it, and there was no other trace of it ever being installed.
Downloaded the removal tool from here:
https://support.threattracksecurity.com/support/discussions
Everything works fine now.
*facepalm*
