HI,
I have a question that maybe silly to ask,
but can I actually port forward, on my router, two different WAN ports to the same LAN port located at the same Internal IP address?
Where I work seems having blocked all ports except those needed, port 80/443 something.
To solve this I understand that, besides using serfish(which I am not sure with its security), I can actually set a port forward on the router to forward a WAN Port 80 to LAN Port 22 of my server for the SSH to work as it should.
But the question is, can I keep the original port forward of WAN 22 to LAN 22 as well? As I want to take it as the port I use normally while no blockage presents.
Now I have tried with port 443(As well the original port forward W22->L22 is kept) and by testing on serfish it looks both ports are usable.
While, do you know if this setting would really work?
Thank you for your attention.
